Thu Aug 28, 2014 5:23 pm
Will the ultra 1800 white lighting work with the VLX vagabond extreme and how long to recycle at full power
Thu Aug 28, 2014 5:31 pm
Yes. Recycle should be about the same as from powerline - under 4 seconds.
Fri Aug 29, 2014 8:08 am
I use a pair of them in the Vagabond-Mini without an issue. I would recommend unscrewing the modeling light else it might flicker a bit at times.
They do seem to run all day without an issue, maybe 400 shots (If I use one Vagabond-Mini per head) which is surprising given the Mini's size. I usually run 5 heads off two Mini units on location.
Extreme would be nicer and a better mounting bracket too it appears. The Mini's bracket and me never get along and I'm surprised I haven't snapped it off yet too.
Mack
Fri Sep 05, 2014 11:15 pm
What should be the recycle time for the The White Lightning™ X3200 on Full power with the VLX ?
Mon Sep 08, 2014 9:39 am
1 X3200 would recycle in 4 seconds, the same as in a wall outlet.
Users browsing this forum: Google [Bot] and 16 guests
