Tue Sep 09, 2014 8:23 pm
Hi,
First I love my vega mini and it has been faithful for almost a year. I was on a shoot yesterday and in the middle of the first session it powered off. I thought it might have overheated but in the process of my fault finding I noticed that if I removed the fuse it would power on no problem ( although the internal fan doesn't come on...not sure if it's supposed to) but once the fuse is in it will power up for less than a second and then shuts off. Any help would be appreciated I have a huge shoot coming up next week
Tue Sep 09, 2014 10:14 pm
By "power on" do you mean the fuel gauge lights come on, or do you also get a light by the USB port?
The fuel gauge lights bypass the fuse, but if the fuse as in place, and a short or other fault was present, this could shut the whole system down.
Tue Sep 09, 2014 10:30 pm
Correct the fuel lights are on but no light by the usb
Wed Sep 10, 2014 9:18 am
Ok, then the battery is just showing its charge status, and not really "turning on". When the fuse is installed, this activates the inverter, which appears to have a fault, and the whole thing shuts down.
If the unit is less than a year old, we can repair it under warranty. I would recommend contacting our repair department directly to establish how to best have this unit repaired.
1-800-443-5542
Repair@paulcbuff.com
Users browsing this forum: No registered users and 6 guests
