Mon Sep 22, 2014 9:06 pm
Hello,
Does anyone have a diagram that shows the different sizes of reflectors and the coverage they give out? I've been looking everywhere for one.
Thanks
Tue Sep 23, 2014 9:39 am
Not exactly. However, the chart linked below will show what the spread will be at varying degree spreads. This chart is for 7" reflectors and grids. To calculate a specific spread for a specific size reflector, use the measurement for 7" reflectors, then add the difference in reflector size to the end spread.
For example, 7" reflector with a 30 degree spread at 10 feet will illuminate a circle of about 72 inches. The 18 OMNI is 18 inches in diameter, or 11 inches more than the 7" reflector. This will result in a circle of about 83 inches in diameter.
Also, remember beam spread is measured from centerline out to -1f. Beyond that, you can have various rates of fall off, from gentle to almost spotlight-like hardness. The beam spread measurements do no describe the fall off pattern.
http://www.paulcbuff.com/popups/grids/7_grid_chart.php
Users browsing this forum: No registered users and 125 guests
