Wed Nov 12, 2014 9:34 pm
I have 2 WL X3200 and 2 WL x1600 monolights. I would like a case that can hold all of them along with the 4 power cords, reflectors with a little extra room for small accessories like Pocket Wizards, sync cables and extra flash tubes, grids, etc.... Anyone know if it's possible in this case?
Not PCB related but I also have two Avenger 4039CS stands and two PCB non-air assist light stands. Is anyone aware of a case, preferably with wheels, that's great for carting light stands around? I'm pretty sure it would have to be a hard case because each Avenger stand weighs about 30lbs.
Thanks for any help in advance.
Sat Nov 15, 2014 11:35 am
This is my setup
6 Einstein's in Pelican im2950
(about same size as 1650)
you will need to check if 4 WL will fit
https://dl.dropboxusercontent.com/u/648 ... 20Copy.jpg
Mon Nov 17, 2014 10:26 am
the WL 3200 fit in my 1650 fine (not standing up of course, but straight across) so yes 4 wl shouldn't be a problem - I believe I had that many in there
Let me say however, I'm no longer a fan of filling up a case like the 1650 and use smaller cases and a rock n roll cart. Having the 1650 full with lighting gear can make it unwieldy heavy with greater chance of bumping a wall, hurting a back, etc..
Mon Dec 15, 2014 3:14 pm
Here's my setup.
https://www.flickr.com/photos/124358022 ... 029287102/
Pelican 1560 with 3 Einsteins
3 power cords
2 vml's
Users browsing this forum: No registered users and 59 guests
