Sat Jan 10, 2015 12:19 pm
Hi
tried to located topic on this matter but with no luck.
This morning my Cyber Commander screen turned all white in my hand during an adjustment! :o
Changed battery..
Removed the SD card..
Change again the Duracell....
desperate (big shoot coming next week)
Any idea, like a reset switch something...
thanks for any help
Mon Jan 12, 2015 11:22 am
This is likely a hardware failure and would need to be repaired. It would not hurt to reflash the firmware, just in case, but I would not really expect that to work. If you would like to try this, do not use the firmware sourced from the website if you are running V50 firmware. Instead, contact us via email, and we will send you a modified firmware to try (the firmware is the same, it is the installation process that needs to be changed).
If you are running something other than V50, you can use the update from the website.
http://www.paulcbuff.com/fw-cc.php
Users browsing this forum: Majestic-12 [Bot] and 104 guests
