Wed Sep 07, 2016 5:28 pm
My Einstein light had been working fine and is now firing irregularly but not firing when I press the shutter. I thought the problem may have been the trigger or the connection with the line going to the trigger. This has never happened before. I turned off the light to see if it had overheated.
Any idea of what is going on?
Thu Sep 08, 2016 10:41 am
How are you triggering?
Have you tried using the standard sync cord to see if the problem persists?
Does the flash fire consistently from the test button on the back panel?
Users browsing this forum: No registered users and 33 guests
