Mon Mar 20, 2017 9:45 pm
I have a DB400 and after about 10 minutes of operation if I shut it off it will not come back on. I flip the on/off switch and the little light on the bee flickers and does not turn on. Also, the switch seems loose like a tripped breaker in a home breaker box. If I wait about 20 minutes it will come back on. Is there something related to temperature happening or maybe it's overheating?
Thanks!
Wed Mar 22, 2017 9:15 am
That would be a fault in the thermostatic spring inside the power switch. After it cools, it will switch over as expected. We can swap the power switch under warranty.
http://www.paulcbuff.com/repair.php
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 21 guests
