Mon Mar 29, 2010 10:21 pm
I just purchased some AB B800s, a CC and 2 CSR+. I have everything setup and running fine, but for some reason one of b800 model light turns off when adjusting the power settings. When i unplug the telephone wire from the remote jack on the b800, the model light turns back on. When I plug it back in, it turns off again. I then thought it was a faulty wire, so i switch wire with the other light, and still the same thing. I also switch the CSR and still get the same issue. So my question is, What could be at fault?
Tue Mar 30, 2010 10:19 am
Does the light just turn off when adjusting, or does it progressively dim along with the adjustments?
are all model lamp buttons on the light pushed in? is the slider to the far right?
