Mon Sep 27, 2010 7:29 am
I bought my Vagabond II in March 2010. I've had no problem with it until the last time I ran the battery down and charged it after. After it finished charging, the "slow" setting wouldn't turn the unit on. However, the "fast" setting still works. Any idea what's causing this?
Mon Sep 27, 2010 12:13 pm
sounds like a bad switch. If that is the ONLY problem you are having, you can fully charge the battery, and ship only the inverter to us for warranty service (make sure the battery cables are removed from the battery in the mean time). If there are any other issues, or if you want to for good measure, you can send the entire unit to us.
