Sun Oct 10, 2010 9:22 pm
Once the CSXCV is installed can the wireless trigger be disabled and remote sync or optical used instead (without removing the module)
Is it possible to remotely adjust the Einstein using the cyber commander while utilizing optical or remote sync rather than the CSXCV wireless.
I did look for this before i posted.
Thanks
Bryan
Mon Oct 11, 2010 10:34 am
The CSXCV cannot be "disabled" per se, except to uninstall it, but the optical slave and sync jack are still active (unless you disable the slave eye). The optical slave is switchable remotely, so if it needs to be turned on after a remote installation, it can be.
Users browsing this forum: No registered users and 24 guests
