Wed Jan 26, 2011 8:25 pm
Cyber Commander with v.32 firmware (s/n 003301)
When I depress the CC metering button it triggers the studio light, but then frequently reboots itself, and gives an erroneous reading (<f/1). This happens most of the time.
I've set the screen brightness to 45% as this did prevent "other" non-desired reboots; however, this issue with the metering button makes it useless for me.
Does anyone know a fix for this? Thanks in advance.
Best,
Stephen
Thu Jan 27, 2011 10:58 am
The unit can be sent in for an update under warranty. 40% has always prevented the reboot in my experience, however, raising it even higher than 45% may be necessary for it to work until it comes in. Once it has been sent in, it should not reboot at any screen brightness.
Thu Jan 27, 2011 11:48 am
TS: It looks like this customer already installed the latest firmware, so please explain what is meant by "update".
Thu Jan 27, 2011 12:48 pm
A hardware tweak. v.32 firmware does not address rebooting.
Users browsing this forum: No registered users and 76 guests
