 [ 6 posts ]
Sun May 01, 2011 2:45 am
I've had my CST Trigger Transmitter and CSRB Receivers in a drawer for about a year... I pulled them out today and the CSRB's all powered up and act normal (LED blinks every second or so) but the CST is acting strange... If I remove the battery, then insert the battery, the LED blinks three times, and then it will trigger the CSRB's one time via the Test button, then stop working until I remove and replace the battery again. I tested the voltage of the battery and it's ~2.6V. Is this the expected behavior of a low/dead battery, or is something else wrong?
I'm gonna try to get a replacement CR2450 tomorrow, but couldn't resist posting to see if anyone had an answer before then.
Thanks!
Sun May 01, 2011 7:54 am
2.6 V is pretty much a dead CR2450. I think I've had this happen before with a CST but I don't remember for sure. I bet a new battery will have you back in business.
Sun May 01, 2011 10:04 am
multiple blinks on the CST, CSRB, or CSRB+ indicate a low battery condition. A replacement will fix the issue.
Sun May 01, 2011 4:29 pm
Thanks guys - I got a new battery ($6.50 @ Rite Aid) and am back in business!
EDIT: It does seem strange to me that I could reliably get one shot from the dead battery each time I re-inserted it... but, I'll chalk it up to black magic - lesson learned! :)
Sun May 01, 2011 5:59 pm
One pop from a dead battery is pretty common . . . like a car that won't turn the starter but if you let it sit for a while the battery recovers a bit and may then turn the starter a bit.
Tue May 03, 2011 2:36 am
Yeah - the weird thing is that it didn't need any recovery time... I would just pull the battery, stick it in, and hit test - it fired every time (I tried it about 10-15 times in a row.). But I do understand that "strange" things happen to digital electronics when the battery voltage falls below a certain level... this "strange" was just a new one for me! :)
Thanks for the reply!
 [ 6 posts ]
Users browsing this forum: Majestic-12 [Bot] and 49 guests
