Mon Jun 20, 2011 4:10 am
Hi!
I wonder if i can use the cybercommander with the CSXCV on my einsteins to control them remotely and measure them. But still be able to use my skyport to trigger them?
I would have the cc as a remote handheld and my skyport transmitter in the hotshoe and the skyport recivers connected to the enistens via the 3.5mm jack.
Thanks!
Mon Jun 20, 2011 9:04 am
It is rather redundant, but yes, you can trigger this way. Or, if you have other lights that are using the Skyports, you can connect a CST to a Skyport reciever. When the reciever is triggered, it will trigger the CST to fire the lights. This will save you from buying additional Skyports.
Mon Jun 20, 2011 10:15 am
The thing is that i allready have three receivers and a transmitter for the skyport system. With my solution I only have to buy a cc and two cxscv instead of buying a cc, a cybersync transmitter, two cxscv and two receivers for my other lights. I understand that I won't be able to meter my other lights with the cc and that's a shame.
Thanks for your answer!
Users browsing this forum: No registered users and 56 guests
