 [ 14 posts ]
Sun May 03, 2015 9:44 am
marykrn wrote:
. . . . it was mentioned that if I purchased the cyber commander, I wouldn't need to buy a light meter. Would that be referring to something like a sekonic light meter which someone had mentioned to me before? I know also that it was suggested that a cyber commander mostly likely would be overwhelming just starting out like I am, but I would like to know the answer even if I don't necessarily get one now but maybe buy one in the future. . . . . . If anyone knows anyone in the Southern NJ area that would be willing to offer any classes or anything like that, I would love to hear about them!
Good morning, Marykrn
Not to take anything away from the CyberCommander and especially not from you, but learning the CyberCommander at the same time as learning studio lights and lighting *might* be overwhelming. I say *might* because you may know quite a lot and have learned quite a lot already.
The CyberCommander does most if not all of what a Sekonic does as a flash meter and as a light meter. Not everyone is going to like the same gear, though, so you will definitely read some who feel the CyberCommander is confusing and difficult to use. I can see how some might feel that way, but it's important to think of the CyberCommander as having its own little operating system - and one that packs a great amount of functionality into a small package. In my opinion, that means it requires an investment in learning and in practice. Without that - and regular use - I can see where some would say it is overwhelming and confusing to use.
I've learned and practiced and used mine enough now where I don't struggle with it at all.
I live in Chicagoland, so unfortunately I can't offer some first first hand help.
Craig
httpS://www.craigwasselphotoart.com
Sun May 10, 2015 1:12 am
marykrn wrote:
I wanted to ask then, it was mentioned that if I purchased the cyber commander, I wouldn't need to buy a light meter. Would that be referring to something like a sekonic light meter which someone had mentioned to me before? I know also that it was suggested that a cyber commander mostly likely would be overwhelming just starting out like I am, but I would like to know the answer even if I don't necessarily get one now but maybe buy one in the future.
Thank you, thank you, thank you!
Hi marykm,
The Cyber Commander has a bit of a learning cure, but being able to change how bright your lights are without having to move them when they're out of reach is a huge benefit. Without the CC you spend a lot of time and effort every time you have to move the head to change a setting. You also risk not getting it back to the exact same position.
The Cyber Commander has a built in incident flash meter, but does not have a spot meter. I almost never see anyone talk or write about spot metering a strobe's output, but to get specific ratios between different areas of your subject it's invaluable. If you get a Cyber Commander I wouldn't recommend a dedicated flash meter immediately, but in time you may want to get one.
If you get to the point where you do want both incident and spot flash metering I highly recommend the Sekonic 758d (or 758dr), although it's quite expensive. It has a steeper learning curve than the Cyber Commander, but it has many useful abilities that the CC, or many other dedicated meters for that matter, don't have. On the other hand, especially if money is tight, the Cyber Commander may do everything you want. Given the cost of the CC I consider its metering to be a virtually free bonus.
John
Mon May 11, 2015 3:17 pm
Hi Marykrn,
I just joined the forum last night. Like yourself, I am brand new to lighting and have been on the same quest for information! Last fall, I took a local studio lighting class, two of the lights were Alien Bees, I liked the shots we took with them! I also have a cousin that does model photography and uses Alien Bees for location shooting. After exhaustive research (I looked at PCB Alien Bees/Einsteins, Elinchrom, Interfit & Profoto), I decided that PCB offered the best value and repeatedly heard positive comments about customer service. So, I went all in and ordered 2 Einsteins, a Cyber Commander, 2 CyberSync transceivers, a 64" Soft Silver PLM with diffusion fabric & 47" soft box. I opted for Impact stands and bought a Revelli backdrop kit. I am expecting it all to arrive today! Now I'll need to figure it all out! I seriously considered the Alien Bee, but decided on the Einsteins for better control over power levels and the high speed sync capability. Hope you figure out what works best for you! There is a ton of info on the Internet to help answer questions. Stay tuned!
Rick
marykrn wrote:
Wow, I am so overwhelmed with thanks. So many people have taken the time to help me out with all my questions. Some people even going so far as to insert direct links for me. I really do appreciate it. I have been reading and re-reading all your advice and trying to put together my list of "to buys". I wanted to ask then, it was mentioned that if I purchased the cyber commander, I wouldn't need to buy a light meter. Would that be referring to something like a sekonic light meter which someone had mentioned to me before? I know also that it was suggested that a cyber commander mostly likely would be overwhelming just starting out like I am, but I would like to know the answer even if I don't necessarily get one now but maybe buy one in the future. Thanks again for being so helpful and taking time out of your day to help me out. If anyone knows anyone in the Southern NJ area that would be willing to offer any classes or anything like that, I would love to hear about them!
Mon May 11, 2015 4:10 pm
You will find the Einstein to be a fantastic flash unit. However, it does not have High Speed Sync. Rather it has a fast flash duration, particularly at lower power settings. In studio, the flash durations are faster than even the highest shutter speed from what most DSLR's can achieve, and therefore will stop action better than HSS.
If you are looking to increase your shutter speed, and have full frame exposure of flash, the Einstein is not capable of overcoming the camera dependent x-sync speed limitation.
 [ 14 posts ]
Users browsing this forum: No registered users and 302 guests
