 [ 8 posts ]
Wed Nov 24, 2010 1:04 pm
Can these reflectors be painted on the outside? If so, What kind of paint do you recommend using?
Wed Nov 24, 2010 1:34 pm
They should be fine to paint (assuming you mean the metal reflectors like HOBD, 7R, and any paint designed for metal should work. I would buff any smooth surface with a scratchy pad (steel wool, cleaning pad, etc) to give a surface for the paint to adhere to. Also, I would recommend priming the reflector before final coat.
Wed Nov 24, 2010 2:04 pm
Technical Support wrote:
...any paint designed for metal should work. ...
Because of the modeling light, do think using a high temperature paint such as:
http://www.homedepot.com/h_d1/N-5yc1vZ1 ... ogId=10053
would be advisable?
Dave F.
Wed Nov 24, 2010 2:41 pm
I didn't see a temperature spec for regular spray paint, and considering it doesn't cost much more (if any), it is not a bad idea to go for high temp, though I doubt it is absolutely necessary. Certainly would not hurt anything.
Chico,
Any particular reason why you are wanting to paint them?
Wed Nov 24, 2010 4:40 pm
Chico,
My hobby is working on Hot Rods and body work. Not really,personal preference and i like when everything matches=-) Black E640 with satin black Reflector... Cruse in style. Happy Thanksgiving!
Wed Nov 24, 2010 4:59 pm
If you're going with a Hot Rod motif how about some tasteful flames?
Wed Nov 24, 2010 6:03 pm
If anything i'd do some old skool pin striping...
Wed Dec 01, 2010 9:24 pm
To the OP:
If you want some paint that will stand up to fairly high temps as well as solvents and rough handling, check out Aluma-Hyde II : http://www.brownells.com/.aspx/pid=1117 ... DE_reg__II
It's sold by Brownells and I use it to paint rifles, metal and synthetic parts/stocks. Works great and a very tough coating. Doesn't require any primer prep. I've spilled gun bore cleaning solvent on parts painted in Aluma-Hyde with no ill effect.
 [ 8 posts ]
Users browsing this forum: Majestic-12 [Bot] and 80 guests
