 [ 8 posts ]
Mon Feb 07, 2011 7:04 am
Hi,
I am wondering what is the current draw for the Einstein? I tried the Einstein on a 1000w Pure Sinwave inverter and it keeps tripping the overload on the inverter. The inverter is a 1000w with 2000w surge rating and I am not running the modelling light with it.
Mon Feb 07, 2011 12:01 pm
The problem you will run into with many off the shelf inverters is the overload cut off. It sees the spike and shuts off. This may vary from manufacturer to manufacturer, so there may not be one answer. You would need a current limiting inverter to sucessfully do this.
Mathmatically, from a 120V power supply at an +/-10A peak draw, you are pulling +/-1200W. (240V inverters would draw +/-5A, same wattage will result). Even though you have a 2000W peak inverter, it can still see the spike in power consumtion and the overload protection will kick in. This can and probably will still happen with even larger inverters. For these reasons (and others) we havecustomized inverters we use for our Vagabond line power supplies.
Tue Feb 08, 2011 2:04 am
Ah I see, so if I add a current limiter between the lights and the inverter say to 4 amps @ 240v that would help?
I am going to get some Vagabond mini but I urgently need something for this weekend and can't wait for the back order.
Thanks for your help
Nelson
Wed Feb 09, 2011 11:53 am
Yes, that would help. However, given the nature and potential dangers involved in such, we cannot be of assistance in how to do this.
Sat Feb 26, 2011 6:46 pm
@ Nelson
How did you go / did you try installing a current limiter ?
This would solve all of my life's woes if this worked :D !!!
Cheers,
AB.
Sat Feb 26, 2011 7:44 pm
There are no "current limiters" for this purpose. You could try a 500 - 1000W light bulb in series, but wouldn't a Vag mini be a lot more sensible . . . you can run three E640s from one.
Wed Feb 22, 2012 2:33 am
What kind of inverter i use for my solar panel?
Inverter Manufacturer from Pakistan
Last edited by ashleyjames222 on Thu Feb 23, 2012 12:59 am, edited 1 time in total.
Wed Feb 22, 2012 10:46 am
We are a lighting manufacturer who sells only a few models of inverters specifically altered to use with studio flash with the included battery. We do not have any information on what is required or recommended for use with solar panels.
 [ 8 posts ]
Users browsing this forum: No registered users and 73 guests
