Spare Modeling Lamps and Flash Tubes for Einstein
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=130
Author:  geogecko [ Thu Jan 07, 2010 10:24 pm ]
Post subject:  Spare Modeling Lamps and Flash Tubes for Einstein
Paul. Can you specify the specific 250W modeling lamp replacement and which flash tubes are compatible (which is stock, and then are there other options i.e. daylight balanced, UV, etc.) with Einstein. I'd like to order at least a spare of each when I order the strobes.
Jason
Author:  Luap [ Thu Jan 07, 2010 11:27 pm ]
Post subject:  Re: Spare Modeling Lamps and Flash Tubes for Einstein
Jason
Einstein modeling lamp is the same as Zeus - standard bayonet 250Q lamp - in stock and available widely. The flashtube is proprietary to Einstein and in stock and is UV coated and 5600°K balanced. Don't have the exact price . . . about the same as an AB tube.
