Reset Cyber Commander
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=156
Author:  masternm [ Tue Jan 12, 2010 2:20 pm ]
Post subject:  Reset Cyber Commander
How do I reset my CC in order to erase all input information and start fresh?
Author:  Technical Support [ Tue Jan 12, 2010 2:23 pm ]
Post subject:  Re: Reset Cyber Commander
You can go into set up> advanced configuration> SD utilities> and format the card. This will leave the current set up active. From there, just do your normal open from studio in the "open Memory" tab.
TS
Author:  DeepDeish [ Tue Oct 04, 2016 12:20 pm ]
I recently purchased a used Cyber Commander, and when I follow these steps, it still doesn't erase all the previous owner's settings.
https://www.youtube.com/watch?v=mRzQ97_8v4k
Is there no way to completely wipe it to factory settings?
Author:  Technical Support [ Wed Oct 05, 2016 8:46 am ]
Not exactly, since there is no specific "factory settings" other than no specifications. This can be performed by opening a saved set up that has nothing on it. SD15 would be one of many safe bets. This is mainly because if you perform a set up properly, the previous set up is overwritten, whether it is a studio full of lights, or no lights at all.
If you would like, I can send a set up that neutral/typical settings and no lights specified. You can email info@paulcbuff.com (attn: David in the subject line) and request that set up.
incidentally, the link to you tube was set to private, and I was unable to view it. Even if I send the set up to you, I will be more than happy to view the Youtube video, just to ensure the CC is not doing somehting unexpected.
Author:  DeepDeish [ Wed Oct 05, 2016 10:13 am ]
Sorry about that. I don't use YouTube very often. I just changed the video to "public".
Author:  Technical Support [ Wed Oct 05, 2016 3:52 pm ]
Ok, you do have a corruption. This file I referenced earlier will take care of that and act as a kind of factory reset. Just email info@paulcbuff.com (attn: David in the subject line) and request that set up.
