Fri Jan 15, 2010 8:52 am
I'm working on building a lightstick that I will trigger using 1 CSRB+. I was planning on using a splitter to go from the CSRB+ to the PC connector on the flashes. Most of the splitters I see are stereo whereas the CSRB+ is a mono cable. Will there be any reliability problems if I use the stereo splitter?
Thanks in advance,
Corey
Fri Jan 15, 2010 9:50 am
What flash will you be using? Likely, there won't be an issue, but to give you a better idea, the model flash would be helpful.
TS
Fri Jan 15, 2010 11:06 am
here is a link to a Radio Shack 3.5 mono Y splitter:
http://www.radioshack.com/product/index ... Id=2102953
Also, be sure your flashes have similar sync voltages, as two different voltage flashes can cause damage. (i.e. don't use and old Vivitar 285 and an SB900)
TS
Fri Jan 15, 2010 1:17 pm
I think I'll use an SB-900 and an SB-800. Thanks for the link and your comment on mixing flashes. I wasn't planning on it, but, could have easily made that mistake.
Corey
Fri Jan 15, 2010 5:46 pm
You should be fine with those two lights. I have used stereo adapters successfully, but cannot guarantee all will work.
TS
Users browsing this forum: Majestic-12 [Bot] and 85 guests
