| Einstein weight/dimensions https://paulcbuff-techforum.com/viewtopic.php?f=8&t=170 |
| Author: | jrsforums [ Thu Jan 14, 2010 10:46 am ] |
| Post subject: | Einstein weight/dimensions |
One thing I cannot find in the Einstein specs is the weight & dimensions. Such as those provided for the ABs: weight/dimensions B400....................B800..................B1600 weight................2.5 pounds............2.9 pounds..........3.7 pounds dimensions...........9” x 7.5” x 5.5”.....9” x 7.5” x 5.5”.....9” x 7.5” x 5.5” John |
| Author: | Technical Support [ Thu Jan 14, 2010 11:39 am ] |
| Post subject: | Re: Einstein weight/dimensions |
5x6.5x7.75" and right at 4 lbs, without the cords. TS |
| Author: | amplexis [ Thu Jan 14, 2010 2:29 pm ] |
smaller and denser, i like that a lot. an inch and a quarter shorter and an inch thinner than Ab1600! compact is good. |
| Author: | Luap [ Thu Jan 14, 2010 5:38 pm ] |
Actually slightly longer than AB . . . but not much. |
| Author: | jrsforums [ Thu Jan 14, 2010 11:26 pm ] |
Luap wrote: Actually slightly longer than AB . . . but not much. What is the 9" on the dimensions I posted (from the AB specs)? John |
| Author: | Luap [ Fri Jan 15, 2010 12:05 am ] |
These numbers get all balled up depending on whether who writes them includes brackets, lamps, lamp covers, etc. The basic Einstein housing is 4.75" rounded square and is 5.625" long. The lamps and glass dome take it to 7.5" long and the mounting bracket takes it to 6 1/2" high. By contrast, the AB housing is 5.3" slightly rounded square 4.75" long. Don't know who published the 9" long . . . it's more like 8" including the much longer modeling lamp. May be 9" with lamp cover. Visually, I'd say the Einstein looks a bit small than AB. I design them as compact and functional as possible, and personally believe the Einstein form factor to be more ergonomic and visually pleasing. Einstein housing is more reenforced, the accessory mount is vastly improved and it has much improved cooling to accommodate the faster recycle and 250W lamp. Some on DP Review think they are ugly, I think they are elegant and the that Profotos are ugly round tube with no aesthetics at all. To each his own. http://forums.dpreview.com/forums/read. ... e=34186635 what fun they have over there. I know we have 1600 pre orders for Einstein since we started taking them a week ago. This is maybe what Elinchrom or Profoto sells in the US in a year . . . (I don't have their sales data.) |
