| Cybersync Splitter https://paulcbuff-techforum.com/viewtopic.php?f=8&t=173 |
| Author: | cas5 [ Fri Jan 15, 2010 8:52 am ] |
| Post subject: | Cybersync Splitter |
I'm working on building a lightstick that I will trigger using 1 CSRB+. I was planning on using a splitter to go from the CSRB+ to the PC connector on the flashes. Most of the splitters I see are stereo whereas the CSRB+ is a mono cable. Will there be any reliability problems if I use the stereo splitter? Thanks in advance, Corey |
| Author: | Technical Support [ Fri Jan 15, 2010 9:50 am ] |
| Post subject: | Re: Cybersync Splitter |
What flash will you be using? Likely, there won't be an issue, but to give you a better idea, the model flash would be helpful. TS |
| Author: | Technical Support [ Fri Jan 15, 2010 11:06 am ] |
here is a link to a Radio Shack 3.5 mono Y splitter: http://www.radioshack.com/product/index ... Id=2102953 Also, be sure your flashes have similar sync voltages, as two different voltage flashes can cause damage. (i.e. don't use and old Vivitar 285 and an SB900) TS |
| Author: | cas5 [ Fri Jan 15, 2010 1:17 pm ] |
I think I'll use an SB-900 and an SB-800. Thanks for the link and your comment on mixing flashes. I wasn't planning on it, but, could have easily made that mistake. Corey |
| Author: | Technical Support [ Fri Jan 15, 2010 5:46 pm ] |
You should be fine with those two lights. I have used stereo adapters successfully, but cannot guarantee all will work. TS |
