Mon Oct 10, 2011 12:43 pm
I have a couple quick questions on the original Vagabond 1:
1) I know the manual says that the grounding rod is necessary - is that still the case? I ask only because newer systems (i.e. VML) don't seem to need one and I'm wondering if that is due to a different design or if the risk was determined to be small enough that it just wasn't necessary.
2) Do you by chance have the dimensions of the battery handy? I would like to see if I can find a replacement locally to avoid shipping charges but don't have mine available right now.
Thanks!
Mon Oct 10, 2011 4:20 pm
It is not really necessary. If you are in a really high RF environment, then you will want to, but in normal usage, you can forego the grounding rod.
The demensions of the battery are below
15cmW x 9cmD x 9.5cmH
Users browsing this forum: Majestic-12 [Bot] and 79 guests
