Sat Dec 12, 2009 10:09 am
I recently purchased a Vagabond and a CyberSync CSRB+ I plugged in one of my AB800s to the Vagabond and the bee fires just fine. When I plug the CSRB+ in to the "phone jack' connector, turn on the AB8000, when triggered, the strobe, lets out a very quiet ping and will not fire. If I turn it off, disconnect the cybersync and turn the light back on it fires just fine. I recall reading someplace the the cyber sync and Vagabond might interfere with each other. Is that correct? Does anyone have a suggestion? Would it be better to hook in a CyberSync CSR+?
thanks
jim
Sat Dec 12, 2009 2:11 pm
Using the + version via telephone jack requires Cyber Commander. Without CC, the + receiver has no program input to tell it what power to fire at, so it fires the light at some unprogrammed value . . . in this case, zero power.
Until you have CC, don't use the telephone connector . . . use the 1/8" sync connection. I believe this is all in the instructions.
Sat Dec 12, 2009 2:22 pm
THANKS, I have to laugh at my self. That makes perfect sense. I have the Cyber Commander but was just testing it with the CSRB+. I will try it with the CC. Thank you very much!
jim
Users browsing this forum: No registered users and 121 guests
