Mon Feb 27, 2012 9:16 pm
The Rj11 cord connection between my White Lightning strobe and the CSRB+ receiver seems to make a loose connection causing misfiring of the strobes and loss of communication with the CB unit. If I push the rj11 connector as far in as possible and wedge with a wood toothpick it is more reliable but still not perfect. Any suggestions to achieve the best connection would be appreciated.
Tue Feb 28, 2012 10:36 am
Are the spring clips on the RJ11 connections intact and "springy"? If you look in the light's RJ11, do you see the 4 contacts, and are they evenly spaced and of equal height? Can you try a different RJ11 cord to rule out something in the cord?
Wed Feb 29, 2012 10:46 am
Yes, I think new cables are in order, thanks for the tips!
Users browsing this forum: No registered users and 140 guests
