 [ 7 posts ]
Mon Nov 19, 2012 12:41 pm
Hi
I'm using a Sekonic L-478DR and 4 Einsteins/I can only get 3 channels, A,B and C.
I'm able to set the Sekonic up for A,B,C and D but the flashes only go up to A,B,C.
Any advice?
Mon Nov 19, 2012 3:14 pm
Einstein will only go to Zone C in C-TL mode. It will only go to Zone D in CH17-32. I believe this is the case with all C-TL stuff. You will need to contact PocketWizard for any specific details.
Mon Nov 19, 2012 3:36 pm
Thank you for your prompt reply.
I am on channel 17, and zone D will not come up on the Einsteins.
Pocket Wizard?
Mon Nov 19, 2012 3:56 pm
CH17 or C-TL 17? There is a difference. I also assume you are using MC2's?
Mon Nov 19, 2012 4:10 pm
C-TL 17, and yes MC2's
Mon Nov 19, 2012 5:32 pm
C-TL 17 and CH17 are different. Zone D does not appear to be available in C-TL 17. Scroll through all the channels, you will see the designation change.
Fri Nov 23, 2012 10:21 pm
That explains it! Thank you for the clarification.
 [ 7 posts ]
Users browsing this forum: Majestic-12 [Bot] and 93 guests
