Sun Dec 23, 2012 3:18 pm
Hi there:
Will the old White Lightning WL10,000 and WL5,000 be ok to use with the Vagabond Mini Lithium battery packs???
Also, if I use TWO WL10,000 and ONE WL5,000 at full power (about 625WS total) would I get the same number of shots per charge as about One Einstein (more or less)?
And finally, can I plug an extension strip into the Vagabond Mini Lithium so that I can use THREE lights at a time (since the VML seems to only have TWO outlets)?
Thanks in advance.
Mon Dec 24, 2012 3:53 pm
Yes, they lights are compatible, and you should get about the same number of shots or a little less. There is no problem using a splitter of any sort on the VML as you would a regular AC outlet.
Mon Dec 24, 2012 4:09 pm
Thank You!!! and thank you for taking the time to reply on Christmas Eve. :)
Merry Christmas, Happy Holidays, and a Happy New Year.
Users browsing this forum: Bing [Bot] and 88 guests
