Thu Apr 18, 2013 10:09 am
Please excuse the newb question but dosen't the CC wake the Einsteins from standby mode by pressing up on the refresh joystick? I did have them wake once but I cannot get them to wake now by refreshing.
Is it maybe a setting I'm missing? I did save my initial setup as Internal 1 and used the CC to put the lights in standby.
I did a search but found nothing on this issue.
Thanks for any help.
Thu Apr 18, 2013 10:34 am
The "Refresh" command rebroadcasts the current Cyber Commander settings to the receivers. If the Cyber Commander says an E640 should be on, but it is switched off, it will turn on the the light.
However, if the Cyber Commander says the light should be off, and the light is off, then it will not change. If the light is on, it will then turn off.
Probably the easiest thing to do is to create one saved set up with all lights set to standby, and one or as many set ups as you wish with the lights set to ON, and use this function to toggle between on and Standby.
Thu Apr 18, 2013 11:03 am
Thank you very much for your reply. That makes sense now, I think I may have had the lights powered off and the CC set to ON and that's why they refreshed.
Great company and tech support, thank you.
Users browsing this forum: Majestic-12 [Bot] and 86 guests
