Fri Dec 13, 2013 9:33 am
I'd like to keep my VML (2 of them) in a small padded bag, hanging on the light stand while they are in use (Einsteins). I've been using a Think Tank lens bag that fits perfectly, not tight, but snug.
After a two hour shoot (540 pops at 1/8th power), it felt a little warm. Not hot, but probably about 100 or 105 degrees F. Is this bad for the battery/inverter? Should I look for a different way to hang it from a stand? (not crazy about the provided clamp)
Thanks, loving my new PCB lighting system.
Fri Dec 13, 2013 10:38 am
No. Do not run the VMLs while enclosed in a bag.
From page 2 of the VML manual:
WARNING! Do not operate or charge the Vagabond Mini™ Lithium system inside a carry
bag or backpack. Air circulation around the Vagabond Mini™ Lithium system
and charger must be provided. Do not obstruct the Vagabond Mini™ Lithium
system’s internal fan or ventilation holes during use or when charging.
If you let the VML rest on a knuckle or yoke on the light stand, it will be supported by the included clip. You can also hang the VML from the stand by the carry strap.
Fri Dec 13, 2013 11:57 am
Thanks... t
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 38 guests
