| Cyber Commander with Einstein? https://paulcbuff-techforum.com/viewtopic.php?f=8&t=43 |
| Author: | Gary [ Tue Dec 15, 2009 9:15 pm ] |
| Post subject: | Cyber Commander with Einstein? |
What other hardware do I need to use the Cyber Commander with Einstein lights? Thanks, Gary |
| Author: | Luap [ Tue Dec 15, 2009 11:59 pm ] |
| Post subject: | Re: Cyber Commander with Einstein? |
Just the plug in module CSXCVR $29.95. It's all digital and gets it power from the slot on top of the Einstein. Einstein automatically identifies itself to the CC so there is no setup involved. |
| Author: | amplexis [ Sat Dec 19, 2009 10:14 am ] |
will this combination ever support multi stroboscopic flash? |
| Author: | Technical Support [ Mon Dec 21, 2009 10:36 am ] |
While I cant say for sure, i am fairly confident we will not incorporate stroboscopic flash on the CyberCommander. Mainly, this is outside of our target audience. As well, max FPS is 10 on any CS component, and recycle times may not be condusive to stroboscopic flash. If you have an SB800 or 900, (and perhaps others) which have a stroboscopic mode, you can connect the CST or CC to it, set the SB to stroboscopic, and have the SB trigger the fire at up to 10FPS. TS |
