Sun Nov 23, 2014 5:59 pm
I'm using a Vello flash trigger with a b800, and cannot make it work! I got a mono adapter so that the cord would work, but now, testing it, I'm finding that the light is firing when I press the shutter halfway in order to focus, rather than when I actually take the photo. Or rather, I should say that it only fires when the shutter button is halfway pressed-- if I skip that step entirely, it does not fire at all. Obviously, that makes it completely useless. Does anyone have even the slightest clue why it's doing this? Because I'm at a loss....
Amanda
Update: I have since used the cord from the Vello trigger to plug the b800 directly into my camera (a Canon Rebel T3, for reference) which does not have a PC port. Even connecting the light directly to my camera, it still only fires when the shutter is pressed halfway.
Mon Nov 24, 2014 10:25 am
How are you plugging into the camera, since it has no PC port? Are you using the 1/8 jack on the side of the camera in any of the configurations?
Sun Nov 30, 2014 11:21 am
Amanda
That almost sounds like the focus assist beam from your body is setting off the B800 via optical slave.
CraĆ­g
Users browsing this forum: Bing [Bot] and 13 guests
