Can I charge my Vagabond from the USB port ?
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4669
Author:  antiquedave [ Mon Dec 22, 2014 12:37 am ]
Post subject:  Can I charge my Vagabond from the USB port ?
My charger seams to of stopped working (funny melted part of the plastic is the other sign) .
I live in New Zealand and it will take a while to get a replacement sent out so can I charge it from a Vagabond Mini from its USB port ?
Author:  Luap [ Mon Dec 22, 2014 12:42 am ]
Post subject:  Re: Can I charge my Vagabond from the USB port ?
Simple answer = no. The USB port is a USB 5V output jack, not a charging jack. Sorry
Author:  antiquedave [ Mon Dec 22, 2014 3:55 am ]
Bugger :(
Author:  Luap [ Mon Dec 22, 2014 7:01 pm ]
Even if you could charge a VML or copy cat from USB it would take forever to charge . . . USB doesn't provide enough power to charge a battery this large.
Author:  antiquedave [ Mon Dec 22, 2014 7:50 pm ]
I need to get this unit up and running for now . At the moment I am looking at buying a 12v to 16v laptop charger and running the unit (minus the Vagabond battery) off my cars battery until I can import a genuine charger . Can you see any issues with that ?
Author:  Luap [ Mon Dec 22, 2014 10:18 pm ]
Without knowing all the details, it would seem a 14.8V laptop charger, with 16V maximum output should charge the VML battery. Be sure it's rated to charge a 14.8V Lithium battery.
The charger itself, without the battery, probably won't have sufficient energy to run the VML without the battery - use it to charge the battery like the factory charger.
Author:  antiquedave [ Tue Dec 23, 2014 1:01 am ]
I am looking at using a car cigarette lighter outlet as the power supply to the Vagabond unit .
The one im looking at is a step up power supply from 12 volt to 16 volt , 8.5 amp and up to 150 watts which would have too higher output and would fry the Vagabonds battery (which needs a trickle charge) so it would have to be removed from the unit .
Author:  Luap [ Wed Dec 24, 2014 12:06 am ]
VML inverter draws about 20A from the battery during recycle at 16V. It's possible 8.5A may recycle it, but slowly if at all
