Sat Jan 31, 2015 11:39 am
Hello...
I currently use the Einstein with the Cyber trigger/receiver. I would like to use my AB400 as a second light. How do I get the two to flash at the same time....do I need a second receiver for the AB? :roll:
TIA!
Sat Jan 31, 2015 4:32 pm
You can either add a second receiver or, turn the slave on for the AB
Mon Feb 02, 2015 3:09 pm
Yes the AB optical slave eye is a good solution for most situations. However, there a tree times when the slave eye can't see the master flash, or if there are other flashes in the area. In these cases, an additional receiver is a better choice.
