Can I use Einstein units with a silent generator?
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4686
Author:  thrumyeyes500 [ Mon Jan 19, 2015 5:04 am ]
Post subject:  Can I use Einstein units with a silent generator?
Hi,
I have 3 x Einstein units with various modifiers. I also have a mini vagabond which is faulty and won't power my units anymore.
I was thinking of buying a small portable silent generator so that I can use my lights on location in place of the mini vagabond.
Can I use a generator and if so, what size would I need to power an Einstein unit?
Thanks in advance!
Author:  Luap [ Mon Jan 19, 2015 1:11 pm ]
Post subject:  Re: Can I use Einstein units with a silent generator?
Einsteins and most other monolights draw peak current of about 17A each, with ultra fast recycle lights drawing up to twice this amount.
So three monolights will typically draw about 50A at 120V, which is 6000W peak. Most generators will tolerate peak current of about twice their wattage rating. So it would indicate at least a 3000W generator to power three lights. Anything less than that will probably shut the generator down during recycle.
Author:  thrumyeyes500 [ Mon Jan 19, 2015 3:58 pm ]
Thanks for the feedback!
I forgot to mention that I am in Australia. We have 240V power here. Does that mean that I need to multiply 50A by 240V to get the correct peak watts?
Thanks, Allan
Author:  Technical Support [ Mon Jan 19, 2015 5:40 pm ]
Thanks, Allan
No. The Wattage remains the same, so if your Voltage doubles, your Amperage halves. So you would have about 25A times 240V to get to 6000W.
Author:  thrumyeyes500 [ Mon Jan 19, 2015 6:19 pm ]
Thanks, Allan
Ah ok, Brilliant! Thanks for the help with this!!!
