Mon Jan 19, 2015 10:32 pm
Hey guys - any possibility of making a larger PLM? Call me crazy, I use the 86 (and the 64) all the time, but when shooting two people or more, I could use something even larger.
I love the quality of light used with the Einstein, and the zooming is nothing short of amazing, I just need a bit more.
Tue Jan 20, 2015 2:49 pm
I guess you would like a 120" PLM. Doable, but would require pretty much a whole new design because of the weight on the shafts and mounting to Einstein or other light.
Are you using Extreme Silver or Soft Silver.
Tue Jan 20, 2015 2:56 pm
Using the extreme, and diffusion fabric when I want something a bit softer.
I use the size to my advantage - depending on distance and zoom I can make this puppy act like a beauty dish, octabox or reflector. Not to blow hot smoke or anything, but I'm a VERY happy customer.
Tue Jan 20, 2015 5:32 pm
120" would totally work. I'd also be OK mounting the Einstein to the umbrella, with the umbrella mounted on a c-stand, less stress on the light! Maybe a bigger shaft and stronger speedring attachment?
Thu Jul 16, 2015 10:15 am
I think another limitation is the ability of the user to open the umbrella--the 86-inch already maxes out my arm length to open it.
Thu Jul 16, 2015 12:36 pm
If you use two hands and "choke" on the umbrella shaft while opening the umbrella with the other, it's pretty easy. This would scale to a larger umbrella.
Users browsing this forum: No registered users and 78 guests
