| Can I sync my Einstein and Ab together? https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4694 |
| Author: | karinmarie [ Sat Jan 31, 2015 11:39 am ] |
| Post subject: | Can I sync my Einstein and Ab together? |
Hello... I currently use the Einstein with the Cyber trigger/receiver. I would like to use my AB400 as a second light. How do I get the two to flash at the same time....do I need a second receiver for the AB? :roll: TIA! |
| Author: | oducks [ Sat Jan 31, 2015 4:32 pm ] |
| Post subject: | Re: Can I sync my Einstein and Ab together? |
You can either add a second receiver or, turn the slave on for the AB |
| Author: | Technical Support [ Mon Feb 02, 2015 3:09 pm ] |
Yes the AB optical slave eye is a good solution for most situations. However, there a tree times when the slave eye can't see the master flash, or if there are other flashes in the area. In these cases, an additional receiver is a better choice. |
