Mon Feb 09, 2015 8:26 pm
I have a fairly new Vagabond Mini..fully charged battery. When I power the Bee thru wall power works like a charm Plug in the Vagabond Mini and I just get a flicker from the tube no matter what I do. I am sure there must be something quite simple I am doing wrong.
Using RP Jr2 that work great with wall power. Receiver is synching with a short telephone cord to the back of the Bee.
Help appreciated!
Mon Feb 09, 2015 10:29 pm
I presume unplugging the RP remote, the light works fine, yes?
I also presume you have the model lamp turned off (via the remote) since you are on the Vagabond?
If both are correct, be sure the power slider is set to full, the model lamp is set to ON via the remote, but turned off via the back of the head.
Let me know how that works.
Users browsing this forum: No registered users and 73 guests
