cyber commander keeps restarting
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4702
Author:  Nikonshooter [ Fri Feb 06, 2015 9:15 pm ]
Post subject:  cyber commander keeps restarting
My cyber commander keeps restarting everytime it powers on. It is a endless cycle. I first I thought it was the batteries so I switched them out and the same thing keeps happening.
Author:  Technical Support [ Sat Feb 07, 2015 1:37 pm ]
Post subject:  Re: cyber commander keeps restarting
Try removing the microSD card. This is on the left edge, and can be removed by pushing in and letting the card pop out.
Author:  Nikonshooter [ Sun Feb 08, 2015 5:54 pm ]
Thank you so much. It works just fine now.
Author:  Technical Support [ Mon Feb 09, 2015 11:45 am ]
Great! You can re-format the card and it should work fine. If your Cyber Commander has firmware V50 installed, you can format to FAT16 or 32, MAC or PC. (a 4GB or larger card can only be formatted to FAT32). If you are running V41 or earlier, then you must format to FAT16.
If you have saved set ups, you may want to back those up before you format the card. Load the card into the computer, move the PCBUFF folder to the desktop, format the card, then move the PCBUFF folder back to the card. Load the card into the Cyber Commander, and resume normal usage.
