Wed May 20, 2015 11:51 am
The model light light bulbs have burnt out on my ABR800. I replaced them with the hardware store version of the same wattage and they burnt out after about 20 seconds of being on. So i got a higher wattage bulb (20) thinking they wouldn't burnout as easily. Now they oscillate strangely. I'm probably in the wrong with going with a higher bulb but i wasn't sure what else to do. Any thoughts?
Wed May 20, 2015 12:32 pm
What Voltage are the bulbs you are using rated for?
Wed May 20, 2015 8:23 pm
The bulbs that the ABR800 come with are 10W. I just ordered some more 10W ones (the correct ones) In hopes that they wont burn out again and correct the pulsating issue.
Thu May 21, 2015 4:59 pm
The results you are getting are not unexpected if using a 12V 10W or 20W bulb, as the ABR800 is a 24V source.
The replacements from us should work fine.
Users browsing this forum: No registered users and 69 guests
