| Vagabond Lithium Extreme and a Norman D12 or D24 pack https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4749 |
| Author: | vampiredirt [ Sat Apr 25, 2015 12:05 pm ] |
| Post subject: | Vagabond Lithium Extreme and a Norman D12 or D24 pack |
Does anybody have any experience running a Vagabond Lithium Extreme with a 900 series Norman pack? Specifically the D12 or D24 pack? I have several of both and it'd be a dream to use them in places without electricity available. I would just buy a VLE and test it, but I don't want to ruin my pack. They are crazy expensive to fix. |
| Author: | Technical Support [ Mon Apr 27, 2015 3:27 pm ] |
| Post subject: | Re: Vagabond Lithium Extreme and a Norman D12 or D24 pack |
There should not be a problem with using these. If the packs can tolerate a brown out, then they should work. If they can tolerate a sudden power loss, then they should survive a test (i.e. using a power strip power switch, or a breaker tripping). You can contact Norman and ask how low of a voltage the packs can tolerate before the processor crashes. One thing to note, the light may be able to tolerate the voltage drop, but an installed radio receiver may not. |
| Author: | vampiredirt [ Mon Apr 27, 2015 4:23 pm ] |
Thank you for your reply. Very helpful. |
