Fri May 01, 2015 10:11 am
hi,
If I turn on my cyber commander, in the presence of no Einstein units , and I open from studio lights, no bar is visible, wich is what is expected. But if I open from memory 1 or 2, I still see the power bars from my last shoot. Thing is, I did not save this last shoot configuration .
thanks
jb
Fri May 01, 2015 3:29 pm
There is not a way to clear it, per se. But, you can open, say SD50 or 49 or SD 1 or some other location that has nothing saved, then save that nothingness to Internal1 and/or 2. Just keep in mind this may change your frequency and to set it back when you are all done.
Also, I recommend saving at least one real set up. This would serve as a reset should something get askew.
Users browsing this forum: No registered users and 107 guests
