Tue May 26, 2015 11:20 pm
I have an AB800 and the ratchet handle pulls out but the flash unit doesn't budge.
What am I missing here?
Wed May 27, 2015 9:08 am
The ratchet handle pulls out to reposition it for better leverage. It does not release the stand mount with that action alone. Once the handle is repositioned, you would turn it counter clockwise to loosen the mount. If the mount is not loose enough once you rotate through the full range of motion, pull the handle back out, reposition, and rotate again. Repeat as necessary.
Users browsing this forum: No registered users and 83 guests
