B800 Not "seeing."
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4772
Author:  spinningstill [ Sun Jun 07, 2015 11:45 pm ]
Post subject:  B800 Not "seeing."
Any reason why its not seeing. Only a few feet away from another PCB light. Not hidden as I can see flash right behind it.
Author:  Technical Support [ Mon Jun 08, 2015 9:34 am ]
Post subject:  Re: B800 Not "seeing."
Do you have anything plugged into the sync jack? If so, this will lock out the slave eye.
Does it see if a flash is fired directly into the back panel?
How much ambient light is present, and does the response improve if the ambient light is lowered?
Author:  spinningstill [ Mon Jun 08, 2015 9:50 am ]
Oops, doubled checked sync cable. Thought I had taken it out. It sees, how wonderful!
