Sat Jul 18, 2015 8:18 pm
I absolutely love the vagabond mini so was super sad to see it stop working.
I get all green lights but no power out of the sockets.
The fuse looks ok, I've unplugged the battery and plugged it back in.
But the problem still exists, can you please tell me if there is a fix for this problem.
warm regards
Che
Mon Jul 20, 2015 9:04 am
If the "fuel gauge" LED lights are still lit up when no power is available, then the issue is likely within the inverter. This would require the inverter to be repaired or replaced.
If the LED's on the "fuel gauge" go out when there is no power, the problem is likely within the battery, though it could be in the inverter. The likely course of action would be to replace the battery.
Our customer service team can assist you with the best route for getting the unit repaired.
Users browsing this forum: Majestic-12 [Bot] and 14 guests
