Sat Aug 15, 2015 8:12 pm
When opening a saved setting from the Cyber Commander, the flash power opens correctly
but other settings (modeling on/off, slave and more..) change 'randomly (?)'.
I tried this multiple times and saving to different locations (SD/internal) - can't get the CC to save and then remember and open all the flash settings
using 6 Einsteins
Yitzy
Sat Aug 15, 2015 8:30 pm
Did you set the lights on the back panel or in the Cyber Commander before you saved?
Also, did the SD save location (SD1 SD2 etc; though not internal 1 or 2) turn blue when saved?
Sat Aug 15, 2015 8:33 pm
In the Cyber Commander
set the CC to ALL channels and set the settings i wanted, then saved.
Thanks for your quick response
Sat Aug 15, 2015 8:36 pm
Yes i think it turned blue
can test again at the wedding tomorrow
