Cyber Commander - saving settings
https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4815
Author:  yitzy [ Sat Aug 15, 2015 8:12 pm ]
Post subject:  Cyber Commander - saving settings
When opening a saved setting from the Cyber Commander, the flash power opens correctly
but other settings (modeling on/off, slave and more..) change 'randomly (?)'.
I tried this multiple times and saving to different locations (SD/internal) - can't get the CC to save and then remember and open all the flash settings
using 6 Einsteins
Yitzy
Author:  Technical Support [ Sat Aug 15, 2015 8:30 pm ]
Post subject:  Re: Cyber Commander - saving settings
Did you set the lights on the back panel or in the Cyber Commander before you saved?
Also, did the SD save location (SD1 SD2 etc; though not internal 1 or 2) turn blue when saved?
Author:  yitzy [ Sat Aug 15, 2015 8:33 pm ]
In the Cyber Commander
set the CC to ALL channels and set the settings i wanted, then saved.
Thanks for your quick response
Author:  yitzy [ Sat Aug 15, 2015 8:36 pm ]
Yes i think it turned blue
can test again at the wedding tomorrow
