Thu Sep 01, 2016 4:05 am
I've read that this is possible, but I don't know how to set up the Cyber Commander to fire a CSRB Receiver.
If I set my CSRB to Frequency 1 and the Cyber Commander to Frequency 1 and press fire it doesn't work.
Please Help!
Thu Sep 01, 2016 11:32 am
It should work if the Cyber COmmander is set to ALL channels, or in the hotshoe of the camera.
Also, be sure the CSRB is set to 1 and not 9.
Thu Sep 01, 2016 1:46 pm
Thanks. So, it does work if I put the Cyber Commander on All.
What if I'm using 2 Einsteins and one White Lightning with a CSRB and I still want to adjust the power of each Einstein individually? Do I simply go to the other menu to the right, adjust power then go back to All to fire? Because when I'm in All, it adjusts everything at once.
It's all so confusing :)
Fri Sep 02, 2016 10:27 am
Yes, ALL will adjust all lights at once. You can use the left joystick to select the channel of the Einstein and adjust power.
BTW, the CC does not have to be on ALL for the camera to fire the flashes, it only has to be on ALL for the buttons to fire teh flashes.
Users browsing this forum: Majestic-12 [Bot] and 110 guests
