| Honeycomb Grids https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4883 |
| Author: | spinningstill [ Sat Dec 12, 2015 12:03 am ] |
| Post subject: | Honeycomb Grids |
Anyone know how to keep the grids from popping out? |
| Author: | Technical Support [ Mon Dec 14, 2015 10:18 am ] |
| Post subject: | Re: Honeycomb Grids |
If the grids are not sitting properly, it may be the reflector or grid is slightly out of round. Install the grid and rotate it inside the lip of the reflector, and you should feel it snug up. |
| Author: | spinningstill [ Sun Dec 20, 2015 9:26 pm ] |
I have rotated them and only seem to tighten slightly. I am in a controlled environment so not any damage to them. What else do you suggest? They fall out when put at an angle. I have tried tape or a clamp but that doesn't work with the heat from the light. |
| Author: | Technical Support [ Mon Dec 21, 2015 5:30 pm ] |
I assume the spring clip is still present on the outer diameter. Is is possible to bend this out? If not, or if it still does not work, then you should contact customer service to see if there are any warranty options. |
