Sun Feb 07, 2016 12:42 pm
Can someone help? I've been reading but still not figured it out. The question is that I don't know how much flash power to set up initially with before I am going to use my CC to meter all Einstein strobes?
Mon Feb 08, 2016 10:37 am
Generally speaking, it does not really matter. What matters most is where you want to end up. Let's say that you want to shoot at f/8. If you are at a low power and meter at f/4, simply increase power until the meter says f/8 (actually, f/8.0'0). If you are at a high power and meter at f/16, simply reduce power to f/8. Regardless if you go from low power and increase, or high power and decrease, f/8 is still the same power.
Users browsing this forum: Google [Bot] and 46 guests
