| Using Einstein outdoors during winter https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4896 |
| Author: | echantigny [ Tue Feb 09, 2016 1:28 pm ] |
| Post subject: | Using Einstein outdoors during winter |
Hi, I am a bit stressed with the idea of bringing my einsteins outdoors during winter. The low temperature here (-20 C) is the main factor for which I hesitate, but snow is obviously another concern. Can you tell me anything about it? Is there precautions I should take, not take them outside at all... ? Anything would help. Thanks |
| Author: | Technical Support [ Tue Feb 09, 2016 5:49 pm ] |
| Post subject: | Re: Using Einstein outdoors during winter |
There are no problems with using them in that temp range, just don't store them there for long periods of time. Also, make sure when you bring them into warmer temps, you allow them time enough to warm up and any condensation to dry (internally and externally) before use. You can also expect batteries to not provide as much power at -20C as they do at 20C. |
| Author: | echantigny [ Wed Feb 10, 2016 9:34 am ] |
Thank you very much! |
