| Can I fire the Cyber Commander with an optical slave https://paulcbuff-techforum.com/viewtopic.php?f=8&t=4916 |
| Author: | Kristian [ Sat May 07, 2016 8:40 am ] |
| Post subject: | Can I fire the Cyber Commander with an optical slave |
Hi Folks, I want to know if I can fire the Cyber Commander with an optical slave. If I plug an optical slave with no battery (such as a wein peanut or a sonia optical slave) into a cord that has a sub-mini 2.5mm jack on the other end that would go to the Cyber Commander, and set off a flash that the optical slave will see, will the Cyber Commander fire my Einsteins? |
| Author: | Technical Support [ Mon May 09, 2016 9:00 am ] |
| Post subject: | Re: Can I fire the Cyber Commander with an optical slave |
Yes, I just tried this set up, and Cyber Commander, CST and CST2 all work via a slave eye on the hotshoe and a slave eye via the sync jack (CST and CC only). |
| Author: | Kristian [ Tue May 10, 2016 7:55 pm ] |
Perfect! Thank you for going above and beyond what I asked, and for your thorough testing! :) |
| Author: | Kenneth.Rhem [ Sun May 22, 2016 1:05 pm ] |
So, Wein is the answer? viewtopic.php?f=8&t=4013 Any specific wein? |
| Author: | Technical Support [ Sun May 22, 2016 8:37 pm ] |
Hmm. The slave I used was one of our old SS1's, which we made in house. I'm not sure what the difference would be. I don't think I have another type to test with at the moment, but I will see what I can find. |
